SX20 camera cable
We need to use a longer than standard camera cable for SX20. We want to use a Cisco Split cable ( separate female HDMI and RJ 45 ) and 10m HDMI and FTP cables. Unfortunatelly I have found no information about FTP cable pinout. It is a straight or cross cable ? We tried a straight cable and we have no data communication between camera and codec through remote control. I know that pin 3 and 7 are used for data.
Is it mandatory to use a power supply for camera in our case ( 10m cable ) ?I have to add that the camera - powered by data cable - is OK.
Any help is welcome !
Thank you !
VIP Purple
SX20 camera cable
Hello Valentin -
Question has been asked many times here in the forums, here are a few of those discussions that might help you.
https://supportforums.cisco.com/message/3862127
https://supportforums.cisco.com/message/3847335
https://supportforums.cisco.com/message/4075089
https://supportforums.cisco.com/message/3992337
Did you manage to find what
Did you manage to find what the pin outs should be? I've been reading the forums for a while now and have yet to find them.
Thanks in Advance
Hi Richard,I better way of
Hi Richard,
I better way of using long cable for SX20 camera is to use the supplied camera cable ( 3m with special connector to the codec and HDMI and RJ45 connectors to the camera ) and to attached HDMI-HDMI and straight LAN cable to it using female-female HDMI-HDMI and RJ45-RJ45 adapters. Depending of the cables' length you will need external power supply for the camera. All documentation shows that the external power supply is mandatory for longer cables even I use additional 10m HDMI and LAN cables and it works fine without external power supply.
I hope that clarify the situation.
Valentin
Thanks for getting back to me
Thanks for getting back to me Valentin, I am using the Y Splitter with HDMI to HDMI and straight throught RJ45 (5m cable). The camera gets power and video is transmitted but i am not able to control the camera and the web interface on the SX20 shows it as having no camera connected.
If i use the short proprietary cable provided then the camera works fine, but this isn't long enough.
On some of the posts i read it suggests it needs a different PIN out on the RJ45 but it doesnt say what is required
Thanks again,
Richard
VIP Purple
You don't mention the exact y
You don't mention the exact y-cable you're using, if it's either CAB-HDMI-PHD12XS or CAB-PHD4XS2-SPLIT, the pin-outs for both cables are on pgs 19-20 of the PrecisionHD Camera Guide.
I'm using 2x CAB-PHD4XS2
I'm using 2x CAB-PHD4XS2-SPLIT - i have been reading that document but its not overly clear, not to me at least.
I am assuming i need to make a cable as follows
End AEnd B
11
22
36
44
55
63
77
88
To confirm the above PIN out
To confirm the above PIN out works, I am now able to control the camera via the touchpad.
Richard
Any luck with this?  I cannot
Any luck with this?  I cannot control the camera when using the extender cables on the sx20.
VIP Green
For short distances, this
For short distances, this should be OK, especially if you use a decent quality cable.  If you use bad/cheap cable, the voltage drop can be too much over the length of the cable to work correctly.
Another alternative is to use some third party extenders such as these: Vaddio OneLink or these: Sound Control Technologies RC4
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
I made a cable with the above
I made a cable with the above PIN outs in my previous post and that works fine.
Thanks in Advance
Thanks in Advance
1814
