SX20 remote control
Hi everyone,
I´m so sorry for this question, is the Remote control for codec or camera? I want to say if i could locate the codec in datacenter and to use the remote control in meeting room to manage calls and other features.
I appreciate your help.
2 ACCEPTED SOLUTIONS
Silver
SX20 remote control
Hi Juan,
no need to be sorry , question is a question
remote IR is on bothe camera and Codec can be used on both however  only one will work at a time.
Hope that helps
Ravi kr
VIP Purple
Re: SX20 remote control
One things to note, that if the camera is connected to the codec using the it's control cable, than the IR on the codec will be disabled.  The camera's IR takes precedence over the codec's.
SystemUnit IrSensor Mode
Both the Codec C Series and PrecisionHD camera have IR sensors, and only one of them needs to be
enabled at the time. The IR sensor LED is located on the front of the codec and the camera and flickers
when an IR signal is received from the remote control.
Requires user role: ADMIN
Value space:
On: Enable the IR sensor on the codec.
Off: Disable the IR sensor on the codec.
Auto: The system will automatically disable the IR sensor on the codec if the IR sensor at camera is enabled. Otherwise, the IR sensor on the codec will be enabled.
Silver
SX20 remote control
Hi Juan,
Hope that helps
Ravi kr
VIP Purple
Value space:
I appreciate your help. Thanks to Ravi and Patrick for the comments.
463
