SX20 running in maintenance mode
Hello everybody,
i have an issue with my SX20 telepresence device (TC6).
It is running in maintenance mode since 2 days.
Nobody has changed anything.
Do you know how to resolve it please?
2 ACCEPTED SOLUTIONS
Did you try to do a reboot? That could be quick fix that works in 90% of the cases.
The maintenance mode starts if the system crashed for some reason and without
interaction it would stay like that.
If you reboot it and it boots up again to the maintenance mode, please try to do a factory default reset.
Please remember to rate helpful responses and identify helpful or correct answers.
VIP Green
In addition to what Martin has said above - a software update/re-install can also help to solve the Maitenance mode issues.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
VIP Green
Wayne
Wayne
thank to you two,
I tried a reboot but That didn't work. it booted up again to the maintenance mode.
So i did a factory reset and that worked.
But i still don't know why it went on this mode.
VIP Green
Hi Aida,
As Martin indicated in his earlier post, the system will go in to maintenance mode if it has a software crash - it's not always known what causes it - you can try to gather the logs from the unit and look through them while it is still in maintenance mode.
But the fix is usually pretty simple - most times, a reboot can fix it - failing that, the factory reset, or upgrading/re-installing the software on the device will bring it back to life in the majority of other cases.
Wayne
Wayne
644
