SX20 : Setting system password using remote control
Cisco SX20 Quick Set: TC6.1
I know usually system password is set using Web CLI.
But I would like to know if is it possible to set system password using remote control.
If so, can you guide me.
Thanks in advance
1 ACCEPTED SOLUTION
from remote control you can set menu password , System password is not possible from remote .
You can also set using cli commnad .
xcommand SystemUnit AdminPassword Set Password: xxxxxx
hth
Kind regards,
Dharmmesh
hth
Kind regards,
Dharmmesh
Hi Dharmesh
That what i thought.
Thanks for your help
840
