SX20 Video Call Issue
pneithilath
Hi All,
Need your valuable suggestion/ advice for the below mentioned issue.
We are unable to make any video conferencing calls outside the country where possible locally in a newly installed SX20 Telepresence ( Upgraded recently replacing one Cisco/Tandeberg 6000 MXP unit) using an ISDN connectivity via a PRI link connected with a Siemens HiPath 4000 Ver 4 Rel 4.1 Telephone System.
Thank you and best regards,
Pratheesh
Anas Abueideh
Level 9
Level 9
is your PRI is video enabled ? check with the provider for that
other thing, is audio call working ?
Anas
don't forget to rate helpful posts
