SX20 with Cisco Telepresence TX9200
Hi Team,
Hope you are doing good..
My name is Sonu and i want to know that i have SX20 & Telepresence , want to connect each other means i want to call each other is it possible if yes plzzz share with me your excellent expertise or full configuration details so that i can do this.
waiting foryour reply.
I assume since you have a
I assume since you have a TX9200 that you have all the required infrastructure, so yes those two devices can interoperate and are compatible with each other.
full deployment details can be found in the admin and deployment guides.
Hi James,Thanks for reply,I
Hi James,
Thanks for reply,
I have all thing for TX9200 infrastrurcture but both system different network so i want to know that both equipment are different network then this is possible or not.
Thanks.
57
