SX80 - Dual-display?
Hi, looking for some clarification. Does the SX80 support the dual-display feature?
thx,
rf
VIP Green
Yes, similar to the C Series
Yes, similar to the C Series which it is designed to replace, the "dual-display" functionality is included.  The SX80 endpoint has three video outputs (two HDMI and one DVI-I) which can be used to connect your displays (and it's possible to have all three).
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Hello Wayne DeNardi,
Currently we are using Dual 75 inch displays with our SX80 codec , can we upgrade to larger dual displays ?
The room size is 32’x21
VIP Purple
You can use any size display
You can use any size display as you wish, as long as the resolution of the display is supported by the SX80, I've used 42" up to 80" displays with an SX80.  You're not tied to any particular display model or size.
Thank you very much.
1251
