Tandberg 990 MXP TTC7-08. Factory default settings
Hi everybody !
I have some problem with Tandberg 990 MXP TTC7-08, I’m trying to reset this device, but I don’t know how to do this with remote control.
Can someone help me ?
Everyone's tags (1)
1 ACCEPTED SOLUTION
With the DVI output of the codec connected to your display, try the following :
     a) Press ‘Phonebook’ button 5 times (audible tone will be heard)
     b) Press the number ‘2’ key
see if you get the menu back
Tang
VIP Super Bronze
The MXP Administrator Guide (T9) covers this on page 19.
Please rate helpful responses.
Please remember to rate helpful responses and identify helpful or
My Tandberg didn't show me any settings menu
Is you dispaly DVI or Svideo connected to the codec ?
If its DVI then it may be the unit is configred for dual monitors and Menu on PC setting is set to off.
If you are S video connected, then try the DVI if you dont get a menu on either you will need to factory default via serial or web if you know the IP address and password
When you factory defaulty it cna  remove the option keys  so take a recordof them before you factory default.
Tang
11610
