Tandberg MXP 3000 HELP
Hi All,
I'm attempting to control a Tandberg MXP 3000 Codec via Qys Lua Scripting.
I am struggling to read the Local Directory and can only see an xCommand to search through the Corporate Directory ( xCommand corpdirsearch).
Does anyone know of a command that could be used to read/search through the Local directory?
Cheers,
Michael
VIP Green
The Tandberg MXP 3000s are a
The Tandberg MXP 3000s are a very old device, which reach their last day of support and become obsolete on 31 May 2017.  I'd highly recommend that you look at replacing this device with something a little more current.
But, to answer your query, I do not believe there is any command to "Search" through the local directory on the old MXP devices like there is for the Corporate Directory.
You would need to parse the whole directory (xDirectory LocalEntry) in to your external system, then search it within that to get the appropriate entry to dial (ie, to dial entry number 99, the command would be: xcommand diallocalentry localentryid:99).
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Found out that the xommand to
Found out that the xommand to retrieve a contact isnt an xcommand but rather  'dir' (Local directory) or 'globir' (for golbal directory), followed by the id of the contact.
E.g.
dir 1 \r\n
retrieves the first contact in the local directory
for j = 1,200 do -- Number of contacts to request
local tx_message = "globdir " .. j .. "\r\n"
sock:Write(tx_message)
end
44
