TC 6.3 Layout Options
Hi All,
I had a question regarding TC6.3 that I am deploying to my C60s. In the past, if you had monitors set to dual, you would have the ability to press the Layout button on the remote control and select between Fullscreen or Equal Participants. Now it seems as though I have to navigate into the Advanced Settings to change the SelfView Default options in order to change between one or the other. This is way more navigating than I would want my customers to do. Is there an option to enable these options via the Layout button or is there something that we might be missing? Any help would be greatly appreciated. Thanks!
1 REPLY
Yes, you are right.  There are some changes make to layouts from TC5.x to TC6.x.
As you already said, you have to use the selfview configuration commands to acheive what you want.
Alternative, since you are using C60, you can use the TC console to configure custom layouts to acheive what you want.
363
