TC Console for TC6.3
Hi!
Anyone seen TC Console 6.3, I can only find it up to TC6.2:
https://developer.cisco.com/web/telepresence-developer/tools/integrators/tc-console
Martin
Everyone's tags (5)
VIP Green
Hi Martin,
I haven't seen any newer release of TC Console software, but the the 6.2 version appears to work fine on a TC6.3.0 codec.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Re: TC Console for TC6.3
TC Console version 6.2 works fine with TC6.3.
However, if the layout of codec previously has been modified with an earlier version of TC Console you will see a warning when trying to connect.
Text of warning;
Reset broken or unsupported Video Layout component data
The Video Layout component data is broken or not supported by this version of TC console. Confirming this action will reset the Video layout component to the factory defaults.
Pushing the Reset choice will delete all previous changes to the layout, resetting back to factory default.
Pushing the cancel choice you will not be connected to the codec.
Use the reset choice, and start modifying the layout.
641
