TCS streaming low quality
I was wondering if there is any option to reduce the quality of a stream from the content server. I have three option Small / Medium / Large, a nd small uses 500kbps, I would like to reduce it to 250 or 300.
Is there any confirguration that I can apply to do it?
Thanks in advance
1 ACCEPTED SOLUTION
VIP Purple
Hello Manuel -
On the "Site Settings" page under "Advanced streaming options", you can specify target bit rates for small and medium, large will always use the maximum.
VIP Purple
Hello Manuel -
That is exactly what I was looking for.
Thanks!
279
