Community Member
TCS with direct WMP Problem
Dear all
I have a new TCS6.0 on UCS Server which is running very well.
problem is as soon are open the Live unicast stream via WMP direct link
rtsp://192.168.1.1/testlive
sometime the stream are stopped and see the message "Network busy..." sometimes after a while the stream are synchronised and works well.
showing the stream via WebBrowser via Silverlight, I don`t have any Problems.
I have got this issue also on the older TCS5.3 plattform
Any Idea why I have the Problem with direct WMP?
Is it possible to open a direct Windows with Silverlight with the same publishing point?
Any input appreciated
Georg
Everyone's tags (2)
Since you are seeing the WMP error/issue regardless of TCS platform, and the viewing in the web browser via SIlverlight seems to be fine, it could possibly be a client issue. Here is a post from a Microsoft support forum with some steps that can be done on the client that might help:
http://answers.microsoft.com/en-us/windows/forum/windows_7-pictures/media-player-network-too-busy-to-play-file-at/c9be6dc9-b09e-43b2-b48a-3b7116ca4455?msgId=6aa6d580-650b-4935-9e3f-96027f0ee4fc
Community Member
dear allI got more or less
dear all
I got more or less the same problem as georg. the wmp stops after a while.
In the wmp statistics (local player on tcs) i see the selcted bit rate drop, as well as the bandwidth in use.
checking the performance monitor of the windows media services on the tcs i see al lot of late reads and late sends. even with no client connected i get a lot of late reads. also the current file read rate every now and then drops to zero. is that normal behaviour of the tcs encoder?
any ideas?
best regards
igor
263
