Telepresence C40 and C60 CODEC Day light saving time adjustments
I have recently receive C40 and C60 CODECs to install and have noticed the the correct time is not displayed after setting the time zone.  I work in Hawaii and we do not observe day light savings.  Is there a way to adjust the settings to display the correct time (vice changing time zones)?
Everyone's tags (2)
Silver
Re:Telepresence C40 and C60 CODEC Day light saving time adjustme
Hi Scott,
Is the codec provisioned to TMS?
If yes what is the version of the codec and Tms.
Ravi kr.
Sent from Cisco Technical Support Android App
From how I see it in the TC software run on C40/C60/... a daylight saving setting is not needed anymore,
it should be handled by the underlying linux operating system.
I only briefly looked into the bugtoolkit but I did not find anything there.
Here it is 00:00CEST (=+2), which is 22:00GMT and you are -10 right?
I had set my endpoit to your timezone with:
xConfiguration Time Zone: "GMT-10:00 (Hawaii)"
$ date
Thu Sep 12 12:05:45 HST 2013
And thats the time which http://www.worldtimezone.com/ tells me as well for Hawaii
xConfiguration Time Zone: "GMT (Coordinated Universal Time)"
** end
OK
$ date
Thu Sep 12 22:06:40 UTC 2013
xConfiguration Time Zone: "GMT+01:00 (Amsterdam, Berlin, Bern, Rome, Stockholm, Vienna)"
** end
OK
$ date
Fri Sep 13 00:07:00 CEST 2013
(btw, the date is a command executed as root, the xommand from the tsh / admin login)
Which software version do you run?
Your NTP server ok?
I am running TC6.2 (maybe you should try to upgrade if it was a bug).
Check that you set the timezone propper, you have to use the "
Please remember to rate helpful responses and identify helpful or correct answers.
345
