Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
Telepresence Compatibility with Ver 1.3
Hi Team,
I m working on one project where at Parent company have Telepresence of Ver 1.3, and now newer versions are available. Can Newer Ver 1.5 or 1.6 of TP 1300/1100 or TP 3010  will compatible with Ver 1.3 devices/ end points!!!!
If No, than how to upgrade TP with ver 1.3 to newer version!
Pls reply on Urgent basis...
1 REPLY
Green
Re: Telepresence Compatibility with Ver 1.3
Not compatible, you need to upgrade:
Check compatibility matrix
http://www.cisco.com/en/US/partner/docs/telepresence/cts_admin/1_6/compatibility/cts_compatibility_1_6.html
You can upgrade no problem, upgrade is pretty straight forward find SW and info here:
Download SW form CCO
http://tools.cisco.com/support/downloads/go/Redirect.x?mdfid=278875240
Let me know if you have any questions
606
