Telepresence Components question
Hi Team,
I have a quick question for a TP deployment. The client wants to use (3)1300 TP screens, with the CTS Mananger, CUCM Manager, and a Multipoint Switch. The question is that they would also need to incorporate webcam type execs into the mix. What is the recommended solution (CUVA?) and what is the base CUVC item do we need to achieve this? I have been looking at the 3515-12 MCU and wanted to know if this will achieve this request.
Thanks!
1 REPLY
Re: Telepresence Components question
You will need a CUVC to support interoperability with h323 endpoints. The Cisco 3515 or 3545 MCUs are currently supported. Here is a link to the TelePresence 2.0 Design Guide which should be a great help when you design the solution. https://www.cisco.com/en/US/docs/solutions/Enterprise/Video/TelePresence_Network_Systems_2.0_DG.pdf
731
