Community Member
Telepresence cts-p42c20-k9
Hi experts,
I need to know how to connect Touch8 unit with codec cts-p42c20-k9, I have just one ethernet interface, so Do I need PoE unit or switch to connect touch unit with Codec unit?
Please urgent,
Thanks in Advance,
Mohammad
Everyone's tags (1)
3 ACCEPTED SOLUTIONS
Community Member
My apologies if you are connecting to a c20 you connect over lan.  You would plug the panel into a lan port in the wall or table and ensure it is on thesame subnet. Give the panel a static ip. Once it is set you and search for devices to pair.
Silver
Re: Telepresence cts-p42c20-k9
Hi Mohameed,
yes, you can do that
Community Member
Yes that power adapater is needed.
Community Member
Community Member
Ok.There is just one LAN interface then how can i connect the codec to the internet?
Thanks.
Community Member
Community Member
Thanks. But i want to know because i have one LAN outlet on wall, can i connect touch and codec with switch 8 ports and connect switch to the RJ45 on wall(to internet).
Thanks for ur helping me.
Silver
Hi Mohameed,
Community Member
Thanks Micheal and AMit . Last question, Does this switch must be support PoE service and I don't need that Adapter unit?
Community Member
472
