Telepresence Exchange - Study Roadmap
Hi all,
I am going to be assigned to a Telepresence project with use of Telepresence Echange Server, Multipoint Switch, Telepresence Manager and of course some video end points but have no information on that yet. The overall design is that all the solution components will be hosted on a private cloud.
I was wondering if anybody could give me, from your experience, the best study path o roadmap of all the components that could enable me to have good knowledge on this technology.
Thank you in advance for any suggestions.
Remi
2 ACCEPTED SOLUTIONS
Silver
Re: Telepresence Exchange - Study Roadmap
Hii,
My name is Mubashshir from Telepresence support team. I would say that whenever you start studying about any technology, you should start from its base first. I think the best path to this as well would be to go from its base.
Start studying about the endpoints and protocols that actually make videoconferencing take place. Once you get the concept as to how the endpoints work, it would be easy for you to climb the ladder and study about the Telepresence Manager and the Multipoint switch.
Hence first identify the endpoints you would be working with. Once you know that, get the administrative guides for those endpoints and understand how they work. Next you can study the Multipoint switch, etc.
Mubashshir Akhtar
Thanks Mubashshir Akhtar
Bronze
Hi Remi,
There are specialization  certification available right now, which are meant for Telepresence Endpoint, CTMS etc.
Check following link:
http://www.cisco.com/web/learning/le3/le2/le41/le79/video_certifications/telepresence_solutions/learning_certification_type_home_extra_level.html
which include following certification code: 642-185 ITSI
Cisco Press
A variety of Cisco Press titles may be useful reference for this specialization. These titles can be purchased through the Cisco Marketplace Bookstore,or directly from Cisco Press.
If you check following link:
https://learningnetwork.cisco.com/docs/DOC-6480
this include details about course, and i think this certification will be great help to you.
Vivek
Silver
Hii,
Mubashshir Akhtar
Hi Mubashshir,
Thanks very much for all the suggestions. In regards to certifications/specializations, what would you recommend to start with?
Remi
Bronze
Hi Remi,
Cisco Press
Vivek
Hi Vivek,
That sounds really good. Thank you so much for your effort.
Best regards,
Remi
Bronze
Hi Remi,
No Problem
Vivek
338
