Telepresence G2 codec compatibility
Can you replace a CTS-CODEC-PRI from a CTS-1000/3000 with a CTS-CODEC-PRI-G2 without changing anything else?
We are looking at purchasing a couple of additional codecs so we can hold spares as there are some of our sites in which it is difficult to get a field engineer into in case something breaks, but I noticed we can't buy CTS-CODEC-PRI anymore.
I just wanted to ensure that if we buy CTS-CODEC-PRI-G2 then we can do a straight swap with the older codecs
1 ACCEPTED SOLUTION
Re: Telepresence G2 codec compatibility
For your question .
Answer :  Yes, primary CTS you can.
http://www.cisco.com/en/US/prod/collateral/ps7060/ps8329/ps8331/ps7315/end_of_life_notice_c51-527689.html
Best is first to contact your local Cisco Account team also.
-Hans
For your question .
-Hans
Thanks very much
979
