Title: Ask the Expert: Cisco TelePresence Management Suite Extension for Microsoft Exchange
Read the bioWith Tim Walker
Welcome to the Cisco Support Community Ask the Expert conversation. This is an opportunity to learn from Cisco expert Tim Walker on how to install and upgrade the Cisco TelePresence Management Suite Extension for Microsoft Exchange (TMSXE 3.0). You can also ask troubleshooting questions as well as best practices.
Tim Walker is an escalation engineer within the Cisco TelePresence Solutions Group (TSG) in Cisco’s Technical Assistance Center, Reston, Virginia. Before joining Cisco, he worked at TANDBERG as a product support engineer (SME) for TANDBERG TelePresence Management Suite (TMS) products, TMS Microsoft Exchange integration, and Lotus Notes integration products. Tim has over 15 years of experience as a systems and network administrator and holds several TANDBERG certifications.
Remember to use the rating system to let Tim know if you have received an adequate response.
Tim might not be able to answer each question due to the volume expected during this event. Remember that you can continue the conversation on the  Collaboration, Voice and Video sub-community TelePresence discussion forum shortly after the event. This event lasts through July 6, 2012. Visit this forum often to view responses to your questions and the questions of other community members.
This event is the continuation from the live webcast that Tim gave on Tuesday June 26th. You can review the slides of the presentation here.
Related links:
Video
FAQ Document
Read the presentation from Tim Walker on the TMS extension with Ms Exchange. Does Cisco has any such technical discussion or overview of installation on TMS extension for Lotus Notes ? We ran into problems for integrating TMS with our LN infrastructure, as there were some dependencies which are not clearly documented.
rgds.,
A customer
Vasudevan Chari,
Doha, Qatar
There is a installation document for the Cisco Telepresence Management Suite Extensions for IBM Lotus Notes.  The link is below.  There are additional documents as well.  If you are experiencing an issue with installing the application I would highly recommend for you to open a service request with the Telepresence Support Group(TSG).
The engineers in the TSG will be able to assist you with deploying application in your environment and if there are issues that require a higher level of engineer they will have a path to escalating your service request.
http://www.cisco.com/en/US/docs/telepresence/infrastructure/tmsxn/install_guide/Cisco_TMSXN_install_getting_started_guide_11-3-1.pdf
If the answer to your issue is not covered in this document then again I would highly recommend for you to open a support service request.
Tim
Tim,  is that the latest document as it is dated June 2011?
Also, I noticed that most of the document are TMSXE for Exchange but I have an upcoming Lotus Notes and TMS integration and want to see more docs about this.  Where can I find them?
The TMSXE for Domino or Lotus Notes, where is the best place to install it, TMS or a totally separate server or VM?
thanks
Yes that is the latest install guide for the Lotus Notes integration application for the 11.3.1 version.  The Lotus Notes integration is installed on the Domino server.  If you have any additional questions please feel free to post them here and we will get you the answers.
Several things to remember when deploying Lotus Notes integration.
1.  Make sure that you follow the documentation.
2.  Make sure that the configuration lines that are added to the notes.ini file are added at the top of the files so that they processed early when the note.ini file is accessed.
3.  Make sure that the Agents for the Lotus Integration are pointed to the correct Domino server.
4.  Make sure that the service account actually has a mailbox on the Domino server where the integration is installed.
5.  Make sure that the account (tmsconfuser)that will booking the resources in TMS is a member of the Site Administrators group in TMS.
Re: Title: Ask the Expert: Cisco TelePresence Management Suite E
Hi Tim,
I'm still trying to understand what is the purpose of the TMSXE product and will appreciate your help (just a sentence or two, explaining the reason why TMSXE was created). I can't say I'm expert in Exchange or TMS but I did have a chance to work with both. Still, I don't remember TMSXE existed while TMS was still Tandberg product. Is it a new product, introduced with TMS version 13.x or it was available even for TMS 12.x?
Cheers,
Tenaro
The Cisco TelePresence Management Suite Externsion for Microsoft Exchange (TMSXE) product is an extension for the Cisco Telepresence Management Suite (Cisco TMS) that enables video conference scheduling via Microsoft Outlook, and replicate Cisco TMS conferences to Outlook room calendars.
TANDBERG called this application TANDBERG Conferencing eXtensions for Microsoft Exchange which has been changed to the Cisco TMSXE.  With the 2.2 release of the TCX application the name was officially changed to TMSXE but the application performed the same function of making it possible users your environment to schedule Cisco TelePresence endpoints and third party telepresence endpoints managed by Cisco TMS in videoconferences using Microsoft Outlook and have those video conferences automatically connected by Cisco TMS.
Tim
Tim,
On page 16 of your slide, it says that one of the requirements is CTMS version 13.1.2.  Is this really a requirement or was that a typo wherein it should say TMS version 13.1.2?
Yes, that's obviously "Cisco TMS 13.1.2"
Good to confirm as there is the CTMS which is the Cisco TelePresence Multipoint Switch as well
Hi Tim!
How about backup and restore of TMS system?
As I know all the data is stored in MS SQL database. IS it enough to backup only the database?
I've done some testing before and found an interesting fact.
If I make a database backup and then delete the local user from local provisioning group after restoring the database the user deleted isn't restored.
When you say "delete the local user from the local provisioning group" are you talking about the local windows account(tmsconfuser)?
Was this webex recorded?  Can I stream a copy of the webconference?
Chris
I found Tim Walker's slide deck but his webcast is not posted in the Expert series website.
Tim, where and when can this be posted?
You can fined the session record there:
www.ciscolive365.com
Search TMSXE keyword in the Session Catalog
Hello all,
Thank you for your interest on this topic. The recording of the video is posted at  https://supportforums.cisco.com/videos/4009.
There is also a FAQ document with all the questions and answers from the live event.. You can access the document at  https://supportforums.cisco.com/docs/DOC-25574
If you want to see the slides of the live presentation, access those at  https://supportforums.cisco.com/docs/DOC-25186
Kind Regards,
Cisco Moderator
Tim,
I mean the user that can be created here: Systems -> Provisioning -> Directory  in Catalog->Local Directory
The user that you created is under the Provisioning Directory.  Although there is a table in the TMS database that stores a portion of the Provisioning Directory information user account information is stored in the OpenDS database if you are using the Legacy TMS Agent and in the TMPE database if you are using the Provisioning Extensions.
If you are using the Legacy TMS Agent then you would of had to also taken a TMS Agent back under Administrative Tools>Configuration>TMS Agent Settings and restored that along with restoring the TMS database.  These are two separate databases.
If you are having issues with this then I would suggest that you open a case with the Cisco Telepresence Support Group and we can take a look into this for you.
Tim
Hi Tim.
I've made some testing and have another question.
First of all I made a TMS Agent backup and than I deleted a user.
Than I disabled replication on VCS Control TMS Agent;
Than I cleared the list of Replicating agents.
Than I complited the restore TMS-Agent.
After that I saw the deleted user in the Provisioning Directory. So the user was restored.
But when I enabled replication on VCS Control TMS agent the user disappeared again.
Is it correct behavior?
Andrii
Hello Tim,
I've found the next information in the
Cisco_TMS_Agent_Legacy_Provisioning_Guide_13-2:
"The Cisco TMS Agent replicates through a multi-master replication process, meaning that no one database is the master of all. The Cisco TMS Agents on the Cisco TMSs (if in a Cisco TMS redundant setup) and Cisco VCSs (if in a cluster) continually check with one another for changes and differences between them. All provisioning configuration changes must be made via the Cisco TMS Provisioning Directory UI."
So, it seems like after restore TMS thinks that VCS Control has more actual database (without interesting user) and TMS replicates provisioning user database from the VCS Control.
Could you please give me the right algorithm to restore user directory?
Andrii
Yes it was recorded.  We are working on getting it uploaded.
The recording can be viewed by going to the below link:
If you have questions after reviewing the recording feel free to post them here.
Tim
Tim,  I went thru your slide deck presentation for TMSXE and it is Exchange centric.  While I dont blame you since Exchange controls the market, a Domino or Lotus Notes integration with TMS falls into my plate and now I am trying to get as much documentation or skills for this.
Where are the slides or docs for Domino or Notes integration?
thanks
Anacleto,
Kind Regards,
Cisco Moderator
We have not provided an Ask the Expert webinar on the topic of the Lotus Notes integration with TMS.  If this is something that you would be interested in seeing Cisco offer please post that here and we will see about offering this as part of the Ask the Expert Webinar series.
I would be interested in providing this as this is a product that I am also a SME.
The documentation for the TMS Lotus Notes integration can be downloaded from the Cisco.com website as well as the installer.
Tim
4429
