TMS PROBLEM
One of our clients have TMS... and they add domain to the firm, so now they had 2 domains (and also two active directories)
After they did it the Scheduler is not working for the people with the new domain.
Can i register 2 domains in the TMS or just one.. if yes how i do it?
Shy
  • TelePresence
Everyone's tags (1)
TMS PROBLEM
Looks like its not supported currently, plz check the following enhancement which is still open
https://tools.cisco.com/bugsearch/bug/CSCub22236/?reffering_site=dumpcr
Manish
Re: TMS PROBLEM
That's not correct. This enhancement is for TMS to be able to look at more than one domain when it comes to this particular setting.
In this case, all you need to do is have a trust...preferably a two way trust...between the two domains so the users from the domain in which TMS is not in can authenticate appropriately so as to get access to the TMS and/or the scheduler.
298
