Community Member
TMS Scheduled conferences using Conductor, TS and EPs trunked/registered to CUCM...
I was wondering if ANYONE (from either Cisco internally or a Partner/Customer) have experience deploying the following scenario in either a LAB or production environment OR if the following scenario is even possibile -
We already know directly from Cisco that the following scenario is supported -
Ad-hoc and Rendezvous conferences using Conductor, TS and EPs trunked/registered to CUCM.
We are going to deploy Collaboration Edge so there is also a VCS-C and VCS-E in their infrastructure, but all EPs will register directly to CUCM.
1 x CUCM SW - 10.0(1)
1 x Conductor - xc2.2
4 x TS (3 clustered and 1 stand alone)- 3.1(1.80)
1 x TMS - 14.3.2
2 x VCS - x8.1
We have also been told by Cisco sales that this is a possible scenario by using a cluster (we will use 3 in a cluster) of TS for Scheduled conferences and then 1 stand-alone TS for Ad-hoc and Rendezvous (but there is no documentation supporting this)...
The only documentation i can find states that you need a seperate TS registered to a VCS with TMS for the scheduled conferences -
http://www.cisco.com/en/US/docs/telepresence/infrastructure/conductor/release_note/optimized_conferencing_for_cisco_unified_cm_vcs_release_note_2-0.pdf
"Scheduled conferences created by Cisco TMS Which are directly hosted on the conference bridges connected to the Cisco VCS,"
This seems a little excessive and am just after some further advice help from someone who has experienced this already.
Many thanks,
Nathan.
415
