TMS templates and Vlan mode
The latest versions of E20 and C-series software support "Vlan mode: Auto" which is great when using voice/data vlans in conjunction with CDP.
TMS 13.1.2 allows you to set Vlan voice mode to auto on E20s using templates but I can't see the same option for C-series, even though TC5 allows me to set this option.
I note that I can set "auto" for Vlan data mode - will this do the same thing?
How can I set all my C-series to Auto using the TMS templates?  Is there a custom command I can use?
In general you can add a custom command with nearly everything in the device templates (see systems > provisioning)
I did not try it, but something like:
Auto
could work for you.
Re: TMS templates and Vlan mode
Thanks Martin.
I tried entering that into the template with no luck, however if I SSH directly to the unit and enter:
xConfiguration Network 1 VLAN Voice Mode: Auto
it works.
I tried entering this command into the template custom command field with the syntax:
But no luck.
Is this the correct syntaxt or do I need to do something different?
I should also add - what's the syntax I need to enter in the custom command field if I want more than one custom command?
I got it working  - I had to enter it in "Custom Configuration" rather than "Custom Command".
The syntax you gave was correct, thanks very much
looking through some old release notes for TMS I saw that "Custom Command" was renamed to "Custom Configuration", hence the confusion.
386
