TMSPE & TMS Issue
Guys,
Details as below.
TMSPE 1.0
TMS 13.2
VCS C 7.1
There are the issue I have encountered. Do hope you guys can give me some opinions.
1. Phonebook status - FAILED.
2. Cannot delete User or Group. (Warning. Server Error)
3. Cannot attach Configuration Templates to Group (Warning. Server Error)
Everyone's tags (3)
TMSPE & TMS Issue
Recheck your setup following the deployment guide.
Check that you use the right protocol and port (like http=80, https=443) and if you want to use https that
this is also active on the TMS and no firewall is blocking the communication in between VCS and TMS.
If this did not help provide more info about your deployment and/or escalate the case to Cisco TAC.
TMSPE & TMS Issue
Thanks for the reply Martin.
I have escalated the case to TAC.
TMSPE & TMS Issue
Thank you for the update!
After the case is resolved It would be great if you could post a short message what the exact issue was and how you resolved it.
TMSPE & TMS Issue
It is solved by uninstalling the Server Role (Web Server) and reinstall back without WebDAV.
Kudos to Cisco TAC.
TMSPE & TMS Issue
thx for the feedback +5
(you hit one golden TMS rule, mentioned in the guides: do not use it for anything else ;-)
1774
