TMSXE - Adding systems
Does anyone know if there are any plans to add additional variables for adding systems in TMSXE. Right now, the only two available for the email pattern are:
{{TmsId}} translates to the system's numeric system ID from Cisco TMS.
{{DisplayName}} translates to the system's display name in Cisco TMS.
When devices are registered with CUCM, the DisplayName is pulled from the description field in the device configuration and populated in TMS as the DisplayName. Since what were really looking for here is an email pattern, it would be nice to have a variable to pull directly from the "Room Name in Exchange" field on the device config.
1 REPLY
Re: TMSXE - Adding systems
You can already do this...although its a bit of a manual process. See page 34 of the TMSXE Install doc:
http://www.cisco.com/en/US/docs/telepresence/infrastructure/tmsxe/install_guide/Cisco_TMSXE_install_guide_3-1-2.pdf#page34
Systems
Email pattern
Last bullet point:
If the mailbox names in your organization cannot be represented by such a pattern, each email address can be edited manually after they have been added to the right-hand list on this configuration tab.
220
