TPS 8710 Console Port Pin Outs
  I immediately need the wiring diagram for the console port on the MSE 8710 blade. I cannot find any docs on CCO and need to cable the console port to terminal server in order to gather data for a TAC SR. Can anyone send me a link to the hardware manual that shows this information or can you provide the pin outs?
Thank you,
Tony
Everyone's tags (4)
2 ACCEPTED SOLUTIONS
Gold
TPS 8710 Consol Port Pin Outs
Pinouts for most Codian-based products are available at
http://www.cisco.com/en/US/docs/telepresence/infrastructure/articles/cisco_telepresence_codian_serial_cable_pinout_kb_119.shtml.
Although this page does not list the TS8710 I'd expect this blade to use the same pinouts.
- Andreas
All ex-Codian infrastructure product use same pin assignment.
Cisco standard serial cable (light blue) with RJ45 interface works on 8710 TelePresence Server Blade as well.
Normal blue Cisco console cable will probably work - our are wired up with the CAB-HD8-ASYNC cables
connect at 38400 bps
Gold
- Andreas
Your answer was great. Thank you for your help. The pin out is exactly what I needed and I now have access to the 8710 console port.
Thanks again!
The e-mail the system sent me didn't show your post, but after viewing it looks great and that pin out worked THank you for your help!
541
