Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Update CTS-EDGE95 (MXP) / License MS
Hello People,
You can tell the difference between:
L-95-85-MS
Order L-MXP-PAK for E-deliveryof Edg95/85MXP NPP Upgrdeto MS
and
L-EDGE-MS
Order L-MXP-PAK for MS Upg for Legacy Edge systems
*Required update MXP95
**NPP license is required?
Thanks!
2 ACCEPTED SOLUTIONS
MXP Endpoint has three "feature" option statuses.
1) Standard - no option
  2) NPP - Enable NPP feature
  3) MS&NPP - Enable both Multisite and NPP feature.
Because MXP Endpoint able to configure only one feature key, when you install MS option key, it actually enable NPP feature in same time.
So purchase MS option key will not require for purchasing NPP license separately.
Please note, above is not apply on C-series Endpoint.
C-series Endpoint support installing multiple feature option keys and able to install multisite (MS) and NPP option key separately.
Silver
Hi Rafael,
From your post above, the MS option looks like MS-EDGE.
Mubashshir Akhtar
Thanks Mubashshir Akhtar
OK for NPP! o client already has!
But, what is the part number I purchase? L-95-85-L-MS or MS-EDGE to enable MS?
Tks!
Silver
Hi Rafael,
Mubashshir Akhtar
Thank you all
435
