Use the 2.nd ethernet port on C.60 Codec for controling.
Hi.
Is it possible to use the 2.nd ethernet port on a c60 codec for sending x.commands to the codec.
My problem is that the controlsystem (AMX) is on a separate, internal network.
Regards.
Henning Telving
Everyone's tags (2)
1 REPLY
Silver
Hi Henning,
The second ethernet port is only used for connecting the Touch Panel to the codec directly so that it can be paired. It cannot be used to send xcommands.
I dont think you can use the AMX control on a different network. I would recommend that you visit the link below for better assistance for AMX :
http://developer.cisco.com/web/tandberg-developer/
Mubashshir Akhtar
Thanks Mubashshir Akhtar
315
