Community Member
Using Cisco InTouch to trigger event on a Crestron controller?
Is it possible to have the Cisco InTouch panel/system trigger an event on a ethernet enabled Crestron controller?
(The codec does not have GPIO outputs so I believe it has to be done over ethernet if possible)
-Torje
If the codec can be connected to the Crestron on a serial I/O then you could use a feedback output from the codec based on a setting change from the InTouch.
Otherwise the only way I would say this is possible is if the InTouch or CODEC outputs feedback over Ethernet that then could be used to trigger the event you desire.
Community Member
Actually, I am shocked I did not think about that... I was too hung up in the Cisco actually sending a command to the Crestron... The Crestron should just monitor the settings change like you say. Should do the trick. Thanks
319
