VCS 8.1 COLLAB EDGE does not work
Hi All,
I am trying to test collab edge functionality on VCS 8.1 and CUCM 9.1.2. DNSs are fine, but telnet does not work for both ports (8443 and 5222). Port 5222 in unreachable. There is no issue with FW, because this ports are opened. I can access port 5222 locally to IM&P server. In VCS-C the status of CUCM and IM&P is Active. Do you have any ideas, what am I missing?
BR,
Sebastjan Kocelj
2 ACCEPTED SOLUTIONS
Are you checking this ports in a VCS E (not VCS C)  running X8.1 and with Remote and Mobile feature enabled?
As you said, your public DNS and external FW should be configured to accept this requests.
The X8.1 have an Automated protection, please revise the internal VCS E Firewall rules and also check the inbound port usage at VCS E menu.
You can also SSH into VCS E using root and use netstat or other Linux commands to check network conectivity.
Hope it helps.
Elter
- I am checking this port on external IP of VCS-E. Remote and Mobile feature IS enabled.
- DNS and FW are configured as supposed to.
- I do not have any FW rules configured on VCS-E, and for sure ASA is forwarding 5222 and 8443 ports to VCS-E. Local Inbound Ports list contains 8443 and 5222.
- I can see that the port 5222 is listened of the internal IP address. Not for ALL.
~ # netstat -an |grep 8443
tcp        0      0 0.0.0.0:8443            0.0.0.0:*               LISTEN
~ # netstat -an |grep 5222
tcp        0      0 192.168.50.1:5222     0.0.0.0:*               LISTEN
So this does not look OK, because local IP is used for 5222 port. After investigating IP settings on VCSE, I have found that the settings for external IP is actually local IP Address. After changing this and restarting the system, the telnet is working and Jabber is connecting via VCSE without VPN. Thanks for the hints...
Hope it helps.
Elter
992
