VCS connect to TMSPE failure
xujf
VCS controll version is 8.9.2 , TMS version is 15.4.
#174 - TMS Provisioning Extension services communication failure - The VCS is unable to communicate with the TMS Provisioning Extension services. Phone book service failures can also occur if TMS does not have any users provisioned against this clust...
I use postman to get information from TMSPE, it is ok, but VCS can not get information from TMSPE.  reason is : www-authenticate code 400.
VCS do not into username and password in Get request,  and TMSPE return with 401 error.
Patrick Sparkman
Did you configure your VCS under the Provisioning tab to use an account that is a member of the Site Administrators group in TMS?
Can VCS communicate with TMS?
Can you verify that you've configured everything per the TMSPE with VCS Deployment Guide?
Thank you, Patrick Sparkman.
  I have resolved this problem.  I got information from the following Link:
 Basic authentication is only be used in Windows server 2012, I delete all other authentication methods.
   I think VCS has a bug in authentication with TMS.
