VCS : directory servise database is not running
I received this warning message for VCS Control. (The directory servise database is not running :state – new : action -).
What does it mean?
I do not see other problems. What affects for this error. Can I manually start the service?
Br. Oleksandr
br Oleksandr
Everyone's tags (1)
Gold
Hi Oleksandr,
the directory service not running would affect provisioning.
The easiest way to resolve this issue would be to reboot the VCS, as that should clear this error.
If the error persists after the reboot, you probably want to open a TAC case to get this sorted out.
Andreas
Re: VCS : directory servise database is not running
We had this issue perpetually with x5 and it did not go away until I did a complete factory reset and upgrade to x6. I worked extensively with tac, but they had no answers.
Im having exactly the same problem. One day our Movi users could not login and found this error in VCS.
It was running X7.0.1 so we upgraded to the latest firmware X7.0.3 as suggested in this forum, but it has made no difference.
I have since downgraded it to X6 and back to X7, performed a xCommand DefaultValuesSet 3, removed it from TMS, purged it from TMS - but still the VCS reports the same error;
Directory service database failure          The directory service database is not running          Raised          Warning                    Restart the system          2012-02-03 13:51:28          1          15016
In SSH if I login as root and run 'cluster' and run (1) Check the TMS agent status of this VCS, it returns:
    | Checking the state of TMS Agent                                        |
Could not connect to ###.###.###.###:4444.  Check that the server is running and
that the provided credentials are valid.
Error details:
javax.naming.CommunicationException: Connection timed out [Root exception is
java.net.ConnectException: Connection timed out]
ERROR
I have now raised a TAC request, as I have no idea what is causing the issue?
The reboot (not restart) VCS is fixed my problem.  This message is occure after shutdown and power on VCS. Im obtain this message for VCS for X.5, X.6, and X7.
best regards
Oleksandr
br Oleksandr
IF rebooting the VCS doesnt fix or correct the issue, simply upgrade your VCS to the current version
For example if you have 6.1 vcs simply upgrade to 6.1
Enjoy
Cesar Fiestas
Just back in December while on a customer install - my VCS Control lost its mind and I had this same exact scenario with the directory database.
In my case - I had an extremely cranky customer and an agressive timeline - so I immediately opened a TAC case and the engineer for my case had me up and running in less than 30 minutes:
This is what he recommended:
1/ SSH to the VCS and login as 'root'.
2/ execute; 'tmsagent_destroy_and_purge_data'
*** Note: The tmsagent_destroy_and_purge_data command may need to be ran two
or three times. If it fails simply execute the command again until it passes.
and the output:
| Preparing to delete all TMS Agent data on this VCS
WARNING: Before running this procedure:
1. On the VCS, create a TMS Agent backup file.
2. If the VCS is clustered or replicates with TMS: on TMS,
go to the TMS Agent tab for this VCS and ensure "Enable TMS Data Replication" is disabled.
After running this procedure:
3. If "Enable TMS Data Replication" was disabled in step 2 above, then re-enable it.
WARNING: All TMS Agent Provisioning and FindMe data on this VCS will
be destroyed.
This procedure resets the TMS Agent LDAP and Replication passwords on
this VCS back to their factory defaults.
Have you performed steps 1 and 2, and are you sure you want to
proceed? (Y/N)y
Destroying and purging (this may take several minutes)
successfully acquired opends lock
Starting opends
Installing OpenDS
Removing old temporary files
Extracting files..
Installing directory server..
Applying configuration changes
Configuring opends after upgrade
Rebuilding indexes
Stopping provisioningd
Starting provisioningd
2011-12-16 01:24:29,189907933: Initializing provisioning
OK
~ # restart
Stopping warningled
Service vmtoolsd is not running
Stopping inactived
Stopping acpid
Service importcontrol is not running
Service winbindd is not running
Stopping hwstatus
Stopping apache2
Stopping crashreportd
Stopping clusterd
Stopping b2bua_launcher
Service telnetd is not running
Stopping phpsessionmonitor
Service pshelld is not running
Stopping proxy-registrationd
Service provisioningserver is not running
Service phonebookserver is not running
Stopping licensemanagerservermain.py
Stopping policyservermain.py
Stopping credentialmanagerservermain.py
Stopping opends
Stopping tandberg
Stopping managementframework
Stopping tmpstored
Stopping crashmonitord
Stopping clusterdb
Stopping clocksyncd
Stopping updatesw
Stopping logrotated
Stopping sysmonitor
Service snmpd is not running
Stopping sshd
/sbin/restart: line 24: 20483 Terminated $i stop
Stopping setkey
Stopping racoon
Stopping ntpd
Stopping LCDd
Stopping syslogd
Stopping dnsmasq
Stopping network interfaces
Stopping packagesd
Flushing firewall rules..complete
Stopping iptablesd
Stopping fail2ban
Shutdown successful
Stopping requestd
Stopping harddisks
Paul
I have tried that, but it does not resolve the issue. The problem looks to be a problem with the database itself (OpenDS) as when I try to restart the service it errors out (see the very bottom of the below log)
~ # tmsagent_destroy_and_purge_data
    | Preparing to delete all TMS Agent data on this VCS                     |
             2. If the VCS is clustered or replicates with TMS: on TMS, go
                then re-enable it.
    WARNING: All TMS Agent Provisioning and FindMe data on this VCS will be destroyed.
    Have you performed steps 1 and 2, and are you sure you want to proceed? (Y/N)Y
cat: /var/run/opendsd.pid: No such file or directory
kill: usage: kill [-s sigspec | -n signum | -sigspec] pid | jobspec ... or kill -l [sigspec]
/tandberg/app/opends/uninstall: line 17: ${LOG_FILE}: ambiguous redirect
Starting opends
Installing OpenDS
Extracting files..
Rebuilding indexes
~ # restart
Stopping warningled
Stopping inactived
Stopping acpid
Stopping winbindd
Stopping hwstatus
Stopping apache2
Stopping clusterd
Stopping opends
ERROR:  Cannot establish a connection to the Directory Server 127.0.0.1:4444.
Verify that the server is running and that the provided credentials are valid.
Details:  Connect Error
Stopping tandberg
Stopping tmpstored
Stopping clusterdb
Stopping clocksyncd
Stopping updatesw
Stopping logrotated
Stopping sysmonitor
Stopping snmpd
Stopping sshd
/sbin/restart: line 24: 27134 Terminated              $i stop
Stopping setkey
Stopping racoon
Stopping ntpd
Stopping LCDd
Stopping syslogd
Stopping dnsmasq
Stopping packagesd
Stopping iptablesd
Stopping fail2ban
Shutdown successful
Stopping requestd
Stopping harddisks
/tmp:                18069m 18232m 24616m
Stopping sysctl
Stopping hostname
Stopping dbus
Starting dbus
dbus[27624]: nss_ldap: failed to bind to LDAP server ldap://dc1.firstconnections.local: Can't contact LDAP server
dbus[27624]: nss_ldap: could not search LDAP server - Server is unavailable
Starting hostname
Starting sysctl
Mounting harddisks
Setting up swapspace version 1, size = 10010128 kB
fsck 1.41.12 (17-May-2010)
e2fsck 1.41.12 (17-May-2010)
/dev/sdb2: clean, 1715/29310976 files, 3813855/58605120 blocks
Starting requestd
Starting fail2ban
2012-02-03 16:03:54,111 fail2ban.server : INFO   Starting Fail2ban v0.8.4
2012-02-03 16:03:54,112 fail2ban.server : INFO   Starting in daemon mode
Configuring iptablesd
Applying system generated IPv4 rules
Applying system generated IPv6 rules
Launching iptables configuration daemon
iptables initialization completed
Starting packagesd
Bringing up network interfaces
Waiting for network readyness...
Starting dnsmasq
Starting syslogd
Starting LCDd
Starting LCDd client
Starting ntpd
Starting racoon
Starting setkey
Starting sshd
Starting snmpd
Starting sysmonitor
Starting logrotated
Starting updatesw
Starting clocksyncd
Starting clusterdb
Starting alarms
Starting crashmonitord
Starting tmpstored
Starting managementframework
Starting tandberg
Starting opends
OpenDS failed to start
Starting credentialmanagerservermain.py
Starting policyservermain.py
Starting licensemanagerservermain.py
2012-02-03 16:05:34,713838011: Initializing provisioning
Starting proxy-registrationd
Starting pshelld
Starting crl_updater
Starting menumaker
Starting phpsessionmonitor
Starting b2bua_launcher
Starting clusterd
Starting crashreportd
Starting apache2
Starting hwstatus
Service winbindd already running.  Not starting.
Fri Feb  3 16:05:39 GMT 2012 S81winbindd startup Failed!
Starting acpid
Starting inactived
Starting vmtoolsd
Starting warningled
~ # /etc/init.d/S77provisioning restart
2012-02-03 16:08:41,322088467: Initializing provisioning
Restarting opends
Usually the following sequence also helps to resolve these types of issues;
1. SSH to the VCS Control, log in as root.
2. Execute the following command:
/etc/init.d/S77provisioning stop
3. Wait for 1 minute, then execute the following commands:
/etc/init.d/S76opends stop
/etc/init.d/S76opends start
/etc/init.d/S77provisioning start
4. Once the provisioning service has started successfully, go to the TMS server, go to systems navigator, open your VCS Control and go to the 'Clustering' tab.
5. Un-check the 'Enable provisioning' checkbox and press save. Wait for the process to finish.
6. Re-check the 'Enable provisioning' checkbox and press save. Wait for the process to finish, this might take a couple of minutes.
However in this case I get the following;
~ # /etc/init.d/S77provisioning stop
~ # /etc/init.d/S76opends stop
Stopping opends
[03/Feb/2012:16:20:41 +0000] category=JEB severity=NOTICE msgID=8847402 msg=The database backend userRoot containing 0 entries has started
Starting opends
Service opends already running. Not starting.
Looks a bit more complicated than I have usually seen..... RMA?
If you try "telnet xxx.xxx.xxx.xxx 4444" you should also usually get a connection established to prove connection to the database.
However in my case, I dont get connection - reiterating that the OpenDS database is not running as it should be.
Not sure how to resolve this one, waiting to hear back from Cisco TAC ...
Hi First Connection Support Team,
Were you able to fix your problem? If so could you please post the fix? Thank you.
Please rate replies and mark question as "answered" if applicable.
No we were not able to fix it in the end. Spent over 6 hours on a WebEx session with Cisco TAC over 2 days, but unable to solve the issue.
In the end we RMA'd the Cisco VCS Control - and now its working again.
5631
