Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
VCS-E: TCP: Possible SYN flooding on port 5061. Sending cookies.
Anyone noticed that message in the logs of your VCS-E as well?
Wonder if there is some generic stuff going on or of it was some DOS.
You can find them in the kernel log which is located in /mnt/harddisk/logs/kernel.
net_ratelimit: 1 callbacks suppressed
So sum up the days where it happens you can use this command when you are logged in as root:
cd /mnt/harddisk/log && grep -i "Possible SYN flooding"  kernel | tr -s " " " " |cut -f 1,2 -d\  |uniq -c
which in my case gave something like:
     6 May 20
     17 Apr 29
   2136 Jul 3
    84 Jul 4
   939 Jul 11
    533 Jul 14
Re: VCS-E: TCP: Possible SYN flooding on port 5061. Sending cook
Hi, Martin
I am seeing this on all our X7.1 Expressways as well.
Have not observed any loss of service though.
Anyone knows what this is?
I hear of this ever so often. This error comes from Linux's standard SYN flood protection, when its TCP backlog gets full. This is hit before the VCS application itself. It is most likely caused by some denial-of-service attack (either deliberate or some misconfiguration). It should not affect normal VCS operation.
Yea, it happens of business hours and Ola noticed it as well we are not alone.
So would be interesting if its just "missconfiguration" or if something else
(like the DOS can cause some other behavior which can be "missused"), ...
Interesting to review where this SIPS (if use application correctly) negotiation came from.
Is this coming from single source IP address which possibility wrong configuration on far end (should notice far end IP address owner), but if source IP address are wide range then possibility DoS.
Not directly related to this original case but from X7.2 plan to support additional TLS security enhancement for avoiding unnecessary TLS negotiation.
- Checking of certificates for incoming TLS connection (control whether the certificate should be checked when TLS connection is made to the Default Zone of a VCS.)
- Define rules identifying what certificate hostnames should be allowed / denied (configure who is allowed to connect to the Default Zone via regex matching on certificates)
Hi Tomonori!
Thank you for your Answer!
I tried briefly to grep on the logfiles in /mnt/harddisk/log to see entries with ip addresses
at the given times but I did not see anything relevant.
Any suggestions which strings I should search for or which log / debug levels I would need,
the other option would be to check with the firewall guys what capabilities we have there to
log/block.
Martin
If VCS-E still receiving this SYN negotiation, please try with tcpdump on VCS just filter with port 5061.
You should write the log on /mnt/harddisk where has space for tcpdump but please make sure stop the dump after certain period (best to rotate the file size by using option command)
yea, I am more interested in the capability in forensics afterwards, as I never noticed that kind of event "live", ...
guess when the only answer is a network dump I might do it with a mirror port.
If you look in the network logs around that time, you may see a bunch of TLS Negotiation Failed errors from other hosts that got through before the Linux kernel did its SYN flood detection. That may give some indication of where the traffic is coming from.
We have once seen a case of this where we suspected some software (unknown) was falling back to a DNS SRV record that pointed to the VCSs, when its usual SIP server was unavailable.
1948
