VCS-Express and VCS Control Integration
I have the following question about the integration between VCS and VCS Express behind NAT devices.
In VCS Control in the traversal client zone configuration shall I use the Global (Real) IP Address in Location > Peer Address or I have to use the private IP address.
1 ACCEPTED SOLUTION
Hi,that depends on how many
that depends on how many interface you have connected on the Expressway. So if you have two interfaces connected then the internal one is configured with private address, and that is the one you would use on the Control to send the traffic to. But from you question I assume you have one interface connected only therefore you will have to use the public ip address to sent traffic to from vcs control.
Ask if you need more information.
Regards//Andrey
1 REPLY
Regards//Andrey
161
