Warning in VCS and TMS ( legacy TMS Agent mode)
Hello.
I have this massage in TMS and VCS system, how this fix?
in TMS: #2057 - Configuration warning - The VCS is running in a legacy TMS Agent mode; you are recommended to switch your system to use a different mode.
in VCS: The VCS is running in a legacy TMS Agent mode; you are recommended to switch your system to use a different mode
How switch to different mode?
1 ACCEPTED SOLUTION
VIP Green
If you're not using
If you're not using Provisioning - remove the Provisioning key from the VCS.
In the web interface, go to Maintenance, Option Keys, select the provisioning key and press the Delete button.
(it could be useful to take a note of the key first in case you decide in the future you want to install it again - but it can be retrieved other ways if you lose it, ie from the Cisco Licencing Portal).
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
If you do use provisioning,
If you do use provisioning, then you need to change to TMSPE if your version of TMS support it, TMSPE v1.0 requires TMS 13.2 or later.
See deployment guide: http://www.cisco.com/c/dam/en/us/td/docs/telepresence/infrastructure/tmspe/install_guide/Cisco_TMSPE_Deployment_Guide_1-0.pdf
WhitePaper: http://www.cisco.com/c/dam/en/us/td/docs/telepresence/infrastructure/tmspe/release_note/Cisco_TMSPE_migration_white_paper.pdf
If you do not use provisioning, then you can turn this off in TMS - or ignore the warning.
/jens
Please rate replies and mark question(s) as "answered" if applicable.
I cant find this option in
I cant find this option in TMS or VCS.
And maybe you know how fix this problem (in attachment). I try launch monitoring, system ask me domain. but my system not in domain.
TMS: Administrative Tools
TMS: Administrative Tools/General Settings/Provisioning Mode
I take it you do not use provisioning then?
/jens
Hello.1. In TMS it`s switch
Hello.
1. In TMS it`s switch off. How do it in VCS?
2. Not help.
VIP Green
If you're not using
Wayne
Wayne
Try the same log-in you use
Try the same log-in you use to log into TMS.
/jens
174
