Community Member
What is Client Solution Package Licenses in TMS
From TMS Administative Tools>Configuration>General Setting:
I See below Licenses:
Total Client Solution Package Licenses:25
Available Client Solution Package Licenses:25
Total System Licenses:3
Available System Licenses:3
What is Client Solution Package Licenses ? How to Order.
in TMS datasheet, There has below License:
LIC-TMS-PE-XX
LIC-MOVI-XX
LIC-JAB-MOB-XX
I want to how if I want use 100 Movi and 100 Jabber for IPAD, how to order ?
Thanks.
Eddie Liu
If I remember it right you needed this licence for the TANDBERG SCHEDULER and TANDBERG INSTANT MESSENGER. And thats not needed for current versions or does not even exist anymore or is included, ...
Not sure, if you only have 3 system licenses, can it be that you run on a trial / demo license?
You would need to have your VCS running the provisioning managed by that TMS,
have a provisioning key for the VCS and the TMS-PE licenses (TMS14) and sure a license for the TMS itself.
ipad and computer based jabbervideo clients use the same license pool.
I would recommend to talk to a Cisco Partner (or to Cisco if you are one) to go through what
is needed and how it can be solved.
You remember it right. Now that these products are dead, the license keys are no longer needed.
-Kjetil
462
