Which solution for IP call from Telepresence endpoint?
We are struggling with choosing the best solution for dialing IP address from a telepresence endpoint registered on the CUCM.
As Unified CM cannot dial out to IP addresses, but the VCS can, we found 2 solutions:
  1. use a prefix to route calls using that prfix to the VCS-C through the SIP trunk on the CUCM.
  2. double register all endpoints as SIP endpoints on the CUCM and H323 endpoints on the VCS-C
Option 1
It is the one described in the [Cisco TelePresence Cisco Unified Communications Manager with Cisco VCS (SIP Trunk)] deployment guide. http://www.cisco.com/en/US/docs/telepresence/infrastructure/vcs/config_guide/Cisco_VCS_Cisco_Unified_Communications_Manager_Deployment_Guide_CUCM_8_9_and_X7-2.pdf
See page 47
Option 2
It is to register both Telepresence endpoint as SIP endpoints on the CUCM and H323 endpoints on the VCS
example: 900567@cucm.domain.com on the CUCM and 900567@vcs.domain.com on the VCS
  • On top of the CUCM being setup in Configuration > System Configuration > Provisionning,
  • H323 Mode is set to on in Configuration > System Configuration > NetworkServices
  • And the VCS is setup in Configuration > System Configuration > H323 (with
Dialing ip address 12.3.456.7:
option 1 dial sequence if 7 is the prefix for IP dialing: 7012003456007
option 2 dial sequence: h323:12.3.456.7
Pros & cons:
I find the option 2 way more user firendly. Most user will never understand the add of the "0" in front of the IP address. Option 2 is much more user firendly
However with option 2 IT has to manage double registration.
We are wondering:
  1. If Cisco has a preferred recommended method and if yes, why?
  2. with option 1 can we only place SIP calls to IP address?
  3. if the VCS-C interworking is setup so that it can work as an H323-SIP transcoder, will the VCS
    1. convert SIP to H323 in option 1 if the called endpoint is only a H323 endpoint?
    2. and convert H323 to SIP in option 2 if the called endpoint is a SIP endpoint?
Everyone's tags (5)
372
