x8.1 "Unregister and Block" error
Getting the below error when using "Unregister and block" after upgrading VCS-C and VCS-E to x8.1.
"Unregistering" works, but it obviously doesn't block the offending client from re-registering.
Manually adding the string to the "Deny List" also works ok.
/jens
Please rate replies and mark question(s) as "answered" if applicable.
Everyone's tags (4)
1 ACCEPTED SOLUTION
HI Jens. Bug raised - CSCum22596.  You saying the block doesn't work in this instance either? Once you block and add to Deny its ok no?
VR
Patrick
VR
Patrick
Thanks Patrick,
Blocking works ok when manually unregistering the client/system, and then manually adding this to the Deny List.
cheers jens
510
