XMPP federation and Redundancy
Hi There,
I am running:
- Cluster of 2 Expressway-C in v8.2.2.
- Cluster of 2 Expressway-E in v8.2.2
- Cluster of 3 CUCM in 10.5
- Cluster of 2 IM&P (active/standby) in 10.5
I would like to know is handled the XMPP federation when running a cluster of Expressway E?
I create SRV records for _xmpp-server and _xmpp-client with the same weigth and priority, it works very well, but when on Expressway fall down, no more federation.
For exemple:
User A from Company A and User B from Company B are chatting with Jabber using XMPP federation.
If I have one Expressway-E down in the cluster from Company A, User B (Company B) is no longer able to chat with user from Company A.
I would like to know if there are best practices or design as it looks not clearly stated in the documentation.
Thanks.
VIP Super Bronze
Gabriel,I know you need help
Deleted
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Hi Ayodeji,Please open a
Hi Ayodeji,
Please open a separate topic for this if you need explaination, otherwise this topic will confusing for other people.
VIP Super Bronze
Gabriel did you find a
Gabriel did you find a solution to this? If you did can you please share it with us
Yep, I ask my SE about this
Yep, I ask my SE about this and unfortunately this is not supported.
VIP Super Bronze
Are you sayING HA is not
Are you sayING HA is not supported for xmpp  federation?
Nope, not yet supported.But
But after running expressway 8.5.2, I did an failover test and curiously, I kept the federation still available.
134
