*** Error[#193] Creating Process for job 19957916
We receive the above error when attempting to run a windows powershell command.
The command is c:\Scripts\Snapshot_Query.ps1
The user is a domain admin on the target box.
Currently running Tidal version 5.3.1
Any thoughts?
Derrick Au
Level 4
Level 4
Similar issue happened a while back, please check out
https://supportforums.cisco.com/discussion/11670586/error1314-creating-process
Derrick Au
Similar issue but different error message number. Would that point to a different issue?
If not, I'll have the domain admin check the policies. If they are ok, I'll open a support ticket.
*** Error[#1314] Creating Process for job 7413
UnitedNaturalFoods,
You're right -- these are Windows error codes. 1314 relates to user security settings. And 193 relates to running a 64-bit process on a 32-bit OS. Max Galla put together a doc on how to powershell on Tidal. Please check out,
https://supportforums.cisco.com/document/12171771/how-powershell-windows-agent
BR,
Derrick Au
