Community Member
How can I be sure I am licensed for Fault Tolerance within 6.1.0.133?
Originally I was Tidal 6.1.0.133, but have recent upgraded to 6.1.0.310 for my Master and Client Manager, my Plugins are 6.1.0.301. My question is related to my company going to Fault Tolerance / High Availability. I know that the .133 is in the base product and has the FT software and I had logged on to the TES GUI and went to ACTIVITIES where is shows UNLIMITED Agents, but also says "Options" where it says "Fault Tolerance, Dashboard and Command Line". What is the best way to check and verify?
1 REPLY
Community Member
You fault monitor logs will display the current version of the FT after you copy the scheduler.jar file into the lib folder.
It should look somthing like this...after you apply the latest pacth
TIDAL Enterprise Scheduler: version 6.1.0.343
Java version: 1.6.0_43
Java Virtual Machine version: 20.14-b01
09/09 11:58:47:150[68:FMNode Timer]: (mem=1957253720/2058027008) FMNode: FT ack 5 seconds ago.
09/09 11:58:52:158[68:FMNode Timer]: (mem=1956632232/2058027008) FMNode: FT ack 5 seconds ago.
09/09 11:58:53:390[16:Health]: (mem=1956333920/2058027008) MessageDispatcher: Queue Size [=:+:-] : Core[HighPriority:0:6:6,Default:0:0:0,LowPriority:0:0:0]:Special[Special:0:0:0]:Event[Event:0:0:0]:Comm[CommHigh:0:0:0,CommDefault:0:0:0]
09/09 11:58:57:165[68:FMNode Timer]: (mem=1956333920/2058027008) FMNode: FT ack 5 seconds ago.
09/09 11:59:02:173[68:FMNode Timer]: (mem=1956333920/2058027008) FMNode: FT ack 5 seconds ago.
09/09 11:59:07:181[68:FMNode Timer]: (mem=1956333920/2058027008) FMNode: FT ack 5 seconds ago.
176
