How to retrieve PeopleSoft output - logs and reports?
I am looking for some help on getting PeopleSoft logs and reports  via Tidal. The PS adapter has a tab called Other Info where you can specify the  Application server and how you want the Scheduler to handle the output. One  option is use FTP. How do I set this up?
The guide says:
If the job output is being transferred via FTP, the default path is not to a mapped drive or network share, so the path does not start with a drive letter. Instead, the path starts from the FTP login directory and continues to the desired directory.
I already have a FTP user defined which I use for the FTP server. Can I use the same user and give it rights to the Log directory and Report repository on the PS server? I am confused...
One question I have is this: if I define everything in this tab and get it  to work, does it mean that it will apply to all the jobs using the adapter?  There are only few jobs where I would like to be able to get the log and reports  and saved them somewhere else on the network.
Lumi
Everyone's tags (6)
517
