TES and PSJobs
Hello all,
I am looking for some help with PSJobs. I have 3 separate run  controls set up in PS. In TES I use 'Copy From PeopleSoft Job' option which  brings in the PS processes. Each PSJob has 2 processes: a COBOL SQL and an  AppEngine. There is only one catch: the same AppEngine process is used in all 3  PSJobs...Anyway, when I set up the 1st PSjob, the Appengine has the correct  component; when I set up the 2nd and 3rd, the component never changes from the  one used by the 1st PSjob - I have only one component in the drop-down so now  the run control is not correct. I can not automate this for the user; when she  runs it manually in PS everything is fine. I am not sure if this is going to  make a difference but these are jobs for Financial Aid in a campus environment.  I am just hoping that somebody else might've run into this problem because I  just can't figure it out. If needed, I can upload some screen shots.
Thanks! Lumi
337
