11-10-2014 12:55 PM - edited 03-01-2019 09:11 AM
Hi all,
We are in the process of updating from 5.3.1 and I have a few questions, maybe someone can help.
Thanks!
FG
11-10-2014 02:25 PM
Hi Francois,
All very good questions.
1) You will need the Client Manager for the following services: Web Services, Transporter, and Command Line
2) The database conversion occurs during the 6.2 installation. So, whether you are setting up a test or production environment, always perform a backup of the database and work off the copy
3) In fault tolerant mode, at least 2 out of the 3 components must be communicating with each other. If PM fails, FM will detect that it has lost connection with PM and then will try to connect to FM, and vice versa. In the event of a network outage, where Site 1 falls off the grid. PM may continue to run for some time until all pending threads have processed, or it may simply shut down automatically as part of its safety mechanism. In fault tolerant mode, the PM cannot run by itself the other components must be present.
If I left any points out, please feel free to add or correct.
HTH,
Derrick Au
11-11-2014 06:33 AM
Thank you very much for your help.
Really appreciated.
FG
