Trying to lower System Queue to Zero
                  I am running 5.3.1.366 in several environments (Dev, Test, Prod)  When I try to lower the system queue to 0 so that no new jobs launch, my entry is overwritten and goes back to the previous set number.  Even if I set it to 1 it goes back to the previous number.  This is happening on all 3 masters, so I don't think it is a quirk with my install.  In earlier versions of 5.3.1 I was able to do this.
Has anyone else experienced this?  In dev, I stopped Tidal and snuck into the database and edited the limit (definitely not supported by Tidal, but wanted to see what would happen.)  My zero setting stayed 0.
I haven't called Tidal Support about this yet...wondering if it is just me.
Thanks!
Michelle
Re: Trying to lower System Queue to Zero
Did someone write a system event to trap the change, and then performed some action to reset?
Have found system events that send email or snmp traps when the limit is lowered, but no actions that reset the value.
Michelle
Bump.  Is there a event to
Bump.  Is there a event to trigger the system queue to zero automatically in TES? this would be very helpful.
430
