Community Member
Using an Oracle Job to display output
how do you get to display the output of an oracle job? for example i created an anonymous pl/sql block with call to oracle procedure and the code in oracle procedure is using dbms_output.put_line(). to make it work the set serveroutput command must be issued however it is not recognize in tidal oracle job. is there a work around? please advise thank you.
225
