CUAC v9.x Business upgrde to CUAC Standard on V10.
Is it possible to upgrade only the Attendant Console from Business v9.x to Standard v 10.x or do I need to upgrade the entire CUCM x9.x to 10.x?  I understand I can upgrade the to CUAC v 10.x (Business to Advanced) without upgrading the CUCM
You should be able to use
You should be able to use CUACS without upgrading your CUCM release, however, notice the OS restrictions, you might be forced to upgrade.
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/cucmac/cuacs/10_5_1/install_admin_guide/CUACS1051GUIDE.pdf
java
if this helps, please rate
www.cisco.com/go/pdi
Thanks Jaime
Thanks Jaime
78
