07-26-2017 08:27 AM - last edited on 03-25-2019 09:58 PM by ciscomoderator
Hello Experts,
We are planning to use a single PLM to host the licenses for multiple clusters now we also currently have in our 8.5.1.13900-5 cucm environement a mix of servers some that are still in hardware and some that are already in VM, hence we will need to migrate the ones on hardware to VM's and perhaps maybe do a change on the vm size on the ones that are on vm's.
I have done multiple upgrades throughout my cisco life although I always like to ask and get different opinions, Hence I have the following questions to all of you experts.
1- I am doing an upgrade from 8.5.1.13900-5 to 10.5.x what version do you experts recomend me to go to on the 10.5.x range?
2-What should be the best approach to upgrade our 8.5.1.13900-5? Keep in mind that we already have the licenses needed on our PLM to support our nodes and phone count. Hence the new servers will point to the PLM that we have the licenses already loaded. Which means what steps should you take as an expert to do this type of upgrade?
3-What should we worry about during the upgrade?
4-We have gateways running H323 on our 8.5.1.13900-5, do we need to change these VG's to SIP instead?
Thank you !
07-26-2017 08:43 AM
Hi Ceser,
1- I am doing an upgrade from 8.5.1.13900-5 to 10.5.x what version do you experts recommend me to go to on the 10.5.x range?
Ans - It is always recommended to run the latest SU available for that version as it has maximum BUG fixes. If just need to follow the Upgrade guide
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/upgrade/10_5_1/cucm_b_upgrade-and-migration-guide-105.html
All that is mentioned in install \ upgrade guide has to be read to be on same side. Special mention below
The tables below lists the upgrade paths that require COP files. You must install COP files on each node before you begin an upgrade using the Cisco Unified OS Admin interface or the Prime Collaboration Deployment (PCD) tool. You can use PCD to perform a bulk installation of the COP files before you begin the upgrade.
From | To | Upgrade Type |
8.0(x) through 8.5(x) |
10.5(x) |
Refresh upgrade Required COP files: Optional COP files: |
8.6(x) to 9.x |
10.5(x) |
10.x |
10.5(x) |
Standard upgrade; no COP files required |
Ans) Only think i could think is add the new product instance in PLM only once you have upgraded your CUCM to 10.5.X.
Ans) definitely downtime as it is a refresh upgrade server would reboot multiple times as part of the process.
Ans) It would be good if you can move to SIP as all development is heading that way, having been said that its not mandatory
(Rate if it helps)
JB
08-10-2017 04:06 AM
2 - have a look at PCD approach, we went 8.0 to 11.0 using this approach and was very straight forward comparing to other methods I've tried
09-02-2017 05:09 AM
Hi Cesar,
How are you mate ? its been long time.
I would suggest you to use PCD, its the best and very simple. For the version, is there any specific requirement to be on 10.5.x and not going to 11.5.x ?
If you need to upgrade unity as well, you can't use PCD, but you have COBRAS which is also very simple to get it work.
Alok
