04-22-2014 11:03 AM - edited 03-19-2019 08:07 AM
We need to upgrade CUC from 8.6.2 to 9.1.2, is there any compatibility issues with CUCILync 8.6 and also leaving CUCM at version 8.6.2?
04-22-2014 01:18 PM
The CUCILync release notes contain that information, have you reviewed them??
Pretty much any CUC release above 7.X is compatible with any CUCM release 5.X and above.
04-23-2014 04:41 AM
CUCILync Release Notes for 8.6 only state compatibility with CUC 8.6 but the document "Release Notes for Cisco UC Integration for Microsoft Lync Release 8.6" was last updated on September 2012. CUC 9.1.2 was released after this date from what I can tell. I have not been able to determine 9.1.2 is now compatible and the document has not been updated.
04-23-2014 06:17 AM
If it's not there, it's not compatible.
Most likely you'll need a 9.2 version.
04-30-2014 06:41 AM
Java is correct (+5), CUCI-Lync 9.2 is needed with CUCM 9.1, however CUCI-Lync 8.5 will work just fine if you choose to use it.
Chris
05-01-2014 07:33 AM
Upgrader LAB CUC to 9.1.2 to test CUCI-Lync 8.6 compatibility.
Results thus far:
Voice message store (using TCP) shows the following Status Error "The server has rejected the provided credentials"
Note: This happens only when the CUCI-Lync is pointed to the CUC 9.1.2 but the issue goes away when pointed to CUC 8.6 (using the same CSF)
Not sure if this is a configuration/regedit issue or a compatibility issue.
