01-31-2014 01:08 AM - edited 03-19-2019 07:49 AM
Hi, since I migrated the 7921 phone firmware from CP7921G-1.3.3 1.4.4.3 I-CP7921G to drop calls !!!!
products, versions and settings are the following:
on wlc interface wlc:
wlc 4404 - rel 5.2.193.0
QoS:
vlvoce -> Quality of Service (QoS) platinum
WWM -> Policy allowed
802.11a / n Radios - 802.11b/g/n Radios
Voice Parameters:
- Admission Control (ACM) disable
- Load-based CAC disable
Cisco Unified CM Administration
System version: 7.1.5.20000-6
any idea ?
enough to enable ACM and CAC? with the 1.3.3 firware on 7921 this did not happen
01-31-2014 02:07 AM
Hi Mauro,
Which type of calls are being dropped ( IP-IP or PSTN ) ?
How frequently are the calls being dropped?
You should enable detailed callmanager traces on callmanager and capture them for a failed call along with calling and called party information. Steps to enable and capture traces are provided in the following link
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080094e89.shtml
Manish
01-31-2014 02:17 AM
7921 phones have only PERMITIONS for internal calls, however, fall to the calls either by ip to ip and ip to PSTN ....
I'll try with the trace of call manager thanks
